Thread: export to dxf
    I could stop if I wanted to Archman's Avatar
    2003-08
    Dallas, Texas
    255
    Default
    When I export our revit model to dxf, the file size becomes enormous (35Mb Revit file turns into 848Mb dxf file). Is this normal?
    2003-05
    5,153
    Default Re: export to dxf
    Sounds way over the top to me.
    I usually export to R2000 dwg and the file sizes seem comparable to Revit and are often less.
    Try a dwg export to compare.
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    I believe that you export what you see so a hidden line plan results in a smaller file, a wireframe 3D view gives a larger file. Even so your files seem oversize as they ought to be only lines and circles and maybe a little text.
    Try exporting via a sheet view.
    2003-08
    Dallas, Texas
    255
    Thanks beegee and PeterJ. I tried exporting the 3D model to dwg and the file size was much smaller. It's still bigger than the revit file, but at least it's manageable.
    Thanks again
  1. Replies: 0
    Last Post: 2012-07-09, 02:24 PM
  2. Revit Export Issue: Failed to Export Image
    By amax_design in forum Revit Architecture - General
    Last Post: 2009-11-30, 03:13 PM
  3. IFC export
    By vblevin1 in forum Revit Architecture - General
    Last Post: 2009-10-29, 05:24 AM
  4. Export scale option to support Inch export from metric drawings
    Last Post: 2007-09-19, 04:57 AM
  5. improved dwg dwf export: export design options in hierachical way
    By studiodd in forum Revit Architecture - Wish List
    Last Post: 2007-02-28, 11:15 AM
