Results 1 to 6 of 6
Thread: Slides & Library Creation -or- DesignCenter ?
    Active Member chill3490's Avatar
    Twangtown USA
    92
    Lightbulb Slides & Library Creation -or- ....(Edited 1/17/05)?
    The issue in brief:
    I want automatic trimming and attribute requests at symbol insertion. Can this be done with Design Center? If not, I am having difficulty w/ slide & slide library issues. Details follow:
    SLIDES
    The trick for me is recreating the slides and slide library of the original Lite app.
    As it is now, a bunch of weird text appears and no images appear when the VISUAL option is invoked (possibly due to relocating the files from where the app was originally installed). I am trying to use dwg files or sld files from the existing add-on app so as not to re-invent the wheel but it is proving very frustrating as I can only develop this as time allows.
    ********Slide/ Slide Library Creation, FREE Utility or Slide Tips are needed***********
    DETAILS:
    My goal is to level the drafting field for Lite and AutoCAD full version users through adopting the menu code from an obsolete, Lite-based, electrical schematic add-on. This electrical app used toolbars but what I found to be most useful were the app's menu fly-outs/drop-downs. I would like to apply the functionality detailed below for both fluid flow and electrical schematics.
    The steps to include symbols were:
    1. Pick electrical menu drop-down(s)
    2. Pick which symbol family Contacts, Switches, etc.
    3. Pick the 'VISUAL' option which appears at top of each symbol family
    4. A dialog w/ tiles and a list of the symbols' names appeared
    5. Pick the image symbol
    6. Insert symbol
    FUNCTIONALITY:
    The electrical symbol (attributed block) would be inserted, the rung trimmed a preset distance (via menu code) and a attribute dialog would appear. This is very desirable and what I like to develop in-house for both electrical and fluid flow schematics as well.
    ISSUE(S)
    I have the menu code and did some testing already. However, the images don't show as the AutoCAD Lite add-on app and company are defunct (the company was bought out by Autodesk - full version product is now AutoCAD Electrical) The old Lite app we purchased won't properly load on 2004 (+).
    Multas Gratias,
    Clint Hill
    Thrive in '05
    13,654
    Default Re: Slides & Library Creation -or- DesignCenter ?
    Quote Originally Posted by chill
    Hi
    Simple answer, no.
    Have a good one, Mike
    Twangtown USA
    92
    Thanks Mike. Everyone, please see the revised content as I realize DC is out.
    Clint Hill
    Thrive in '05
    13,654
    Hi
    Have you checked for and updated any references in Menu files etc that point to the old Slides / Slide Library location?
    Is this issue/problem also related to your post in the following thread -
    Jan '05 - Customization Corner: Pop Menus, Part I
    Have a browse of the following thread -
    Symbol Library Dialog Box?
    Twangtown USA
    92
    Mike,
    I'm participating in the Pop Menus online class.
    The content on the other website really helped; thanks for making me aware of it!
    Cheers!
    Clint Hill
    Thrive in '05
    13,654
    Hi Clint
    Done.
    Thread moved from the AutoCAD General Forum to this one at the request of Clint.
    Thanks, Mike
    Forum Moderator
    Last edited by Mike.Perry; 2005-02-01 at 11:52 AM. Reason: Correct bad formatting.
  1. Revit Family Library Creation
    By kmarquis in forum Revit Architecture - General
    Last Post: 2010-03-19, 04:46 PM
  2. Slides
    By cadprog in forum Dot Net API
    Last Post: 2009-01-07, 06:11 AM
  3. Routine to print all blocks / slides from a slide library
    By jbortoli in forum AutoCAD Customization
    Last Post: 2007-05-28, 01:18 PM
  4. Creating Slides
    By kweilo in forum AutoCAD Customization
    Last Post: 2004-08-09, 02:01 PM
