Thread: Lost Open Drawing Dialog Box
    33
    Default Lost Open Drawing Dialog Box
    When I try to open an existing drawing, I no longer get the dialog box, only the path of the current drawing in the command line. Any ideas?
    2005-06
    in the upper right corner
    3,442
    Default Re: Lost Open Drawing Dialog Box
    Quote Originally Posted by jacunningham View Post
    Sounds like your variable "FILEDIA" is set to 0 (zero).
    Try this:
    command: FILEDIA <enter> 1 <enter>
    Now try to open a drawing.
    33
    Thanks Ted. That did it.
    2011-07
    12
    Try this:
    I recommend setting CMDDIA to 1 as well. Most of the time it's FILEDIA that's set to 0 but occasionally CMDDIA gets reset to 0 as well. Make sure both of them are set to 1.
    I even added a line to reset those two variables to 1 in a lisp routine that loads with every drawing that gets opened. Looks something like this:
    (setvar "filedia" 1)
    (setvar "cmddia" 1)
  1. Work in drawing while laywalk dialog is open
    Last Post: 2012-12-06, 07:11 PM
  2. List XREFS while in Open Drawing Dialog
    Last Post: 2007-05-25, 03:55 PM
  3. Lost File/Open File/Save Dialog Box on Autocad 2000i
    By thegoffs.89856 in forum AutoCAD General
    Last Post: 2005-06-30, 09:05 PM
