Results 1 to 1 of 1
Thread: UN$ not working well in 2012
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default UN$ not working well in 2012
    I have & use the Un$ lisp to clean up drawings on a very regular basis but with ACA 2012 it frequently does not finish the routine and pops out an error. Is it possible to fix it to work in 12? I'm downloading 2011 now from the subscription site but I hate having multiple installs if I can avoid it - especially on a fresh PC. The error message says:
    Compile error in hidden module: MainUnbind
    The lisp itself will take layers created by binding x-refs that have $ all over them (SA2-11$0$DIM, SA3-11$0$DIM etc) and combine them into one layer (DIM) making cleaning drawings infinitely easier.
    The attached .zip has the lisp used to call the program and the .dvb as well as an old version of the file (not sure why I have it...)
    I'm using ACA 2012x64 on Win7x64
  1. 2012: AUTOCAD 2012 PASTE FUNCTION NOT WORKING
    By tmccotter in forum AutoCAD General
    Last Post: 2014-06-23, 03:55 PM
  2. 2012-Command stopped working
    By mhannan.100562 in forum AutoLISP
    Last Post: 2012-09-05, 06:19 PM
  3. VBA Macro Not working in Autocad 2012 x32
    By timlane in forum VBA/COM Interop
    Last Post: 2012-06-06, 02:18 PM
  4. Working with Subcontractor - AutoCAD 2012 and LT2006?
    By StDoodle in forum AutoCAD LT - General
    Last Post: 2012-05-11, 12:28 PM
  5. 2012: 3d snapping not working in 2012?
    By Jay North in forum Revit - Conceptual Design Tools
    Last Post: 2011-08-29, 11:32 PM
