When you add a view block to a Multi-View Block, all view directions are checked by default. This should be reversed so that no view directions are selected. Rarely, if ever do all views use the same block. This means that you always have to deselect most of the views. It would be more efficient, i.e. less mouse clicks, to only select the views needed. Additionally, functionality could be added so that if your view block's name contained a view name, those views could be automatically selected. For example, if your view block was named "Cabinet-LeftRight", then the Left and Right view directions would be checked for you.
