Thread: Redefining Blocks is changing Xref draw order
    2015-09
    154
    Default Redefining Blocks is changing Xref draw order
    Hi,
    I have come across a situation wherby when a user redefines a block in a drawing it is changing the draw order of the xrefs.
    The block in question is the Plan frame, and is located in paperspace. The user redefines the block and the xrefs change their draw order in the viewport. A regen does not unfortunately correct the issue.
    Has anyone seen this or know of a solution to this problem? I have not had any success looking for similar posts.
    Drawings were created with Civil 3D 2010. The plan frame block is a dynamic block.
    2009-01
    B5
    544
    Default Re: Redefining Blocks is changing Xref draw order
    Nothing to read in the Help files about your question but I wonder if a redefine moves the block(s) to the top in draw order.
    Experiment a little and see?
    2008-07
    Washington DC
    82
    Regen won't affect objects in viewports. The command for that is REGENALL. Does the draw order of the Xrefs change in model space also after redefining the block?
  1. Xref draw order different in Views than Sheets
    By lauren.stassi in forum ACA General
    Last Post: 2010-03-22, 07:32 PM
  2. Entity Draw Order in a Plot Sheet w/xref's
    By imacad in forum AutoCAD General
    Last Post: 2010-02-05, 03:42 PM
  3. Draw Order keeps changing
    By artisteroi in forum AutoCAD General
    Last Post: 2008-12-11, 09:03 PM
  4. Wipeouts and Draw Order in Dynamic Blocks
    By derek.96018 in forum AutoCAD General
    Last Post: 2008-01-22, 12:38 AM
  5. Draw order in blocks
    By norrin in forum VBA/COM Interop
    Last Post: 2006-09-18, 07:17 PM
