Thread: DB of Unequal Double leaf door
    2001-01
    257
    Default DB of Unequal Double leaf door
    Hi All
    I am trying to create a dynamic block of a door with uneven door leaves and I am unable to scale the smaller leaf as I modify the width of the larger one. The door is intended to be inserted and parametrically enlarged to the user specified width. Having said that I have found that I cannot add a lookup table with suggested sizes because that are parametrically enlarged. I also tried to add the sizes as a list to width parameter of the larger door and these too were enlarged parametrically. I am attaching the block in question. Thanks.
    Manuel
    2009-01
    B5
    544
    Default Re: DB of Unequal Double leaf door
    Is this a little closer to what you are looking for?
    (There are problems with it)
  1. 2013: Door Leaf Problem after loading in All in One Door host
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2013-10-15, 05:17 PM
  2. Double Door with different leaf sizes
    By art.theusch in forum Revit Architecture - Families
    Last Post: 2009-02-04, 02:51 PM
  3. Replies: 1
    Last Post: 2008-09-17, 04:23 PM
  4. Unequal leaf door style
    By jaroguy in forum ACA General
    Last Post: 2007-01-12, 09:32 AM
  5. Unequal Leg Double Hung Family request
    By Michael Coviello in forum Revit Architecture - Families
    Last Post: 2006-03-18, 03:05 PM
