Revit MEP 2012, but not necessary limited to MEP. I am using the Transfer Project Standards tool between 27 different files, all started from the same template. Each has the necessary view templates already in them. I am trying to make changes to the first of the 27, and then transfer the project standards to each of the others, making for a consistent looking set of drawings. Unfortunately I am finding that if the view template already exists in the project, the settings do NOT get overwritten. Or at least not completely overwritten (by not completely I had floors and walls set to transparent, settings didn't transfer, Filters had line weights & colors changed, that did not transfer, etc.). At first I was trying to just transfer the view templates, then I remembered you need to get the Filters category as well. Still didn't work. So then I tried transferring every category available, and still didn't work. Has anyone else had difficulty with this?
