Results 1 to 1 of 1
Thread: outline of a sweep is not visible
    2004-06
    335
    Default outline of a sweep is not visible
    Has anyone noticed that the outline of a sweep, where the path is a spline, is not visible in any view (irrespective of the view style) where the sweep path is either not parallel or not perpendicular to the view plane?
    If anyone else can replicate this then it is a bug.
  1. Sweep end grips don't display exactly on sweep ends
    Last Post: 2011-02-16, 05:14 PM
  2. Can't create an in-place sweep using the edge of a hosted sweep?
    Last Post: 2010-08-06, 01:58 PM
  3. Outline of interior visible in 3D model
    By clog boy in forum Revit Architecture - General
    Last Post: 2008-10-24, 06:40 AM
  4. Solid sweep profile is not visible in edit mode
    By hkadani in forum Revit Structure - General
    Last Post: 2008-10-20, 08:23 PM
