Where are 'analyze as' option for columns? It had been in the properties. Thanks.
In Revit 2012, the physical column and the analytical column are now separate elements. Tab to select the analytical column or use the dropdown in the modeless properties pallette to select the analytical column properties; You'll find the Analyze As parameter is now part of the analytical column.
thanks,
-Ken
Ken Marsh
Owner, Marsh API
