I am working on a remodel where we are using existing panels. I have panel schedules and loads. Is there a way in the revit schedule I can manually enter this existing load information?
While doing some testing with this, the way I ended up doing existing loads was by placing a j-box (or something similar) outside of the view, putting the load on it, and tied it to the required panel. Depending on how many existing loads you actually have, it may not be the easiest to do.
Other than that, I don't think there is a way.
Luckily its a small project so this should be pretty easy to do. Great idea, thanks for the input.
In the future I think Revit should make this easier. Being able to input existing loads, breaker size, number of poles and label the loads all manually I think would make a ton of sense and save time.
