Results 1 to 7 of 7
Thread: 2011 Multiple Electrical Connectors
    2011-08
    Default 2011 Multiple Electrical Connectors
    I have created a family with (2) electrical connectors, for which I am setting different demand factors.
    I would like both connectors to be circuited to the same circuit. However, when I circuit one connector, I cannot add the other connector to the same circuit.
    Any ideas?
    Thanks.
    2010-03
    Nashville, TN
    106
    Default Re: 2011 Multiple Electrical Connectors
    You might try placing another Device and adding it to the circuit. Then select that new device, edit circuit and add the remaining connector from the first device. Once all three are connected you can remove the extra device.
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    What piece of equipment requires two demand factors and needs to be on the same circuit?
    2010-03
    Nashville, TN
    106
    I was wondering the same thing. Maybe an AHU but typically that would be two circuits. Fan - motor, compressor - hvac.
    2011-05
    12
    you could need two demand factors if an AHU has a large electric heat section in it. That electric heat, depending on the climate where the project is could have a lower demand than normal. Its an odd situation, but does come up.
    You definitely needd two connectors if the above is true. I had one AHU once that had a ~25hp supply fan and 400A of heat, I needed a seperate circuit for the darn heat.
    2007-03
    890
    Quote Originally Posted by Monza View Post
    A large electric heat will have a separate connection (or at least will be able to connected separately)
    Only small heat elements will be tied into the fan (which is usually small as well)
    2007-08
    Rogers, AR
    103
    A self-contained refrigerated case could have a single feed with multiple demand factors for lighting, fans (continuous), and defrost (non-continuous).
  1. 2014: Electrical Connectors Wrong Position
    By thom.chase676847 in forum Revit MEP - General
    Last Post: 2014-07-30, 02:14 PM
  2. 2011: Renumber electrical connectors
    By matt__w in forum Revit MEP - General
    Last Post: 2013-01-18, 07:23 PM
  3. Multiple Electrical Connectors
    By repp in forum Revit MEP - Families
    Last Post: 2012-11-09, 03:20 PM
  4. Visibility of electrical connectors
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-10-05, 04:33 PM
  5. Electrical Connectors
    By trent.chambers in forum Parts Builder
    Last Post: 2010-06-09, 07:10 PM
