I am trying to get a clearance dimension to change the visibility of a door swing from out to in for the sake of a toilet partition. Everything in the family is working with this exception. I tried to make the clearance dimension a reporting instance parameter so that I could place a conditional statement in the object visibility and I get the following error "A reporting parameter can be used in a formula only if its dimension references are all to host elements in the family."
Can anyone translate?
