Results 1 to 8 of 8
Thread: AJUDA PARA UM INICIANTE
    Question AJUDA PARA UM INICIANTE
    Boas pessoal.
    Estou a desenvolver uma aplicação para AutoCad, e preciso de uma rotina em AutoLisp, ou um SCRIP para o autocad que me faça o seguinte:
    Selecionar as entidades que limitam um ou vários Hatchs...
    E já agora uma outra que me selecione as entidades com a espessura de linha superior a um determinado valor.
    Desde já o meu obrigado...
    Cumps
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,851
    Default Re: AJUDA PARA UM INICIANTE
    From Google Translate...
    Good staff.
    I am developing an application for AutoCAD, and need a routine in AutoLISP, or a SCRIP for autocad I do the following:
    Select the entities that limit one or more Hatchs ...
    By the way I select a different entities with the line width greater than a certain value.
    Already my thanks ...
    Cumps
    Maybe this will help others to provide a solution.
    Sorry, and tks.
    2015-10
    Belgrade, Serbia, Europe
    564
    Even with translation into English, I must admit I don't understand what is the OP's LISP or SCRIPT request... To exclude hatches from selection set and select objects within window defined by point corners (imitation of line with width property), you can use :
    (ssget "w" pt1 pt2 '((-4 . "<not") (0 . "HATCH") (-4 . "not>")))
    M.R.
    BTW. It seems that you asked the same question on CADTutor.net :
    Click here
    2009-03
    London, England
    304
    Quote Originally Posted by marko_ribar View Post
    Another way:
    (ssget "_w" pt1 pt2 '((0 . "~HATCH")))
    2009-11
    5,664
    Quote Originally Posted by Lee Mac View Post
    Another way:
    Tertiary example:
    (ssget '((0 . "~HATCH")))
    Also, for completeness: Original thread
    Computer Specs:
    2012-07
    56
    Hi Guys.
    I need onde lisp that calculates azimuth and distance of a polilyne, with the configuration of UNITS>DIRECTION CONTROL>NORTH. units.pngunits.png
    e.g. 45,20m 25°30'25"
    Thanks
    and sorry for my english, I'm brazilian.
    2005-06
    CORDOBA-ARGENTINA
    273
    Hi RENDER MAN , if I understand ok.
    It mean: ssget all , but not hatch
    What other character , than ~ do other tasks.?
    Thanks in advance
    Meanwhile , I went to the best Saint for LISPER , the SAINT HELP .
    Wild-card characters
    Character
    Definition
    # (pound)
    Matches any single numeric digit.
    @ (at)
    Matches any single alphabetic character.
    . (period)
    Matches any single nonalphanumeric character.
    * (asterisk)
    Matches any character sequence, including an empty one, and it can be used anywhere in the search pattern: at the beginning, middle, or end.
    ? (question mark)
    Matches any single character.
    ~ (tilde)
    If it is the first character in the pattern, it matches anything except the pattern.
    Matches any one of the characters enclosed.
    Matches any single character not enclosed.
    - (hyphen)
    Used inside brackets to specify a range for a single character.
    , (comma)
    Separates two patterns.
    ` (reverse quote)
    Escapes special characters (reads next character literally).
  1. 2014: AGRADECERÍA ALGÚN CONSEJO PARA CREAR DE CERO UN STANDARD BIM PARA REVIT MEP.
    By cansek7677234 in forum Revit Architecture - General
    Last Post: 2015-06-29, 08:39 AM
  2. AJUDA PARA UM INICIANTE
    By luiscarneirorm353485 in forum AutoLISP
    Last Post: 2011-08-29, 01:49 PM
  3. dwg para idw,ajuda urgente
    By hfsmangel314291 in forum AutoCAD General
    Last Post: 2011-02-01, 04:17 PM
  4. help para iniciante!!
    By montesanogoulart in forum AutoLISP
    Last Post: 2009-05-22, 06:58 PM
