Thread: As-built pipe networks
    2005-10
    Allentown PA
    14
    Default As-built pipe networks
    I'm curious how people are creating as-built documents of pipe networks. Are you just adding text next to the label? Adding data to the network? What's your MO?
    2015-12
    Arizona
    2,478
    Default Re: As-built pipe networks
    Quote Originally Posted by kspear View Post
    One strategy, export the network via XML...
    set the original to a no display style (IF only the new data is desired to be seen)
    Edit the network name in the XML file, import and edit as required.
    27
    Kevin -
    What I did was made a copy of the Utility Sheet from the Sheet Set, promote the pipe network and alter it as a record drawing. I would then xref the utility layers from the original plan so that original plan showed.
    Matt
  1. Replies: 0
    Last Post: 2014-05-06, 09:11 PM
  2. 2013: Merging Pipe Networks
    By tim_newsome in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-11-02, 04:40 AM
  3. Joining Pipe Networks
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2012-07-08, 06:56 PM
  4. System Lag with pipe networks
    By zyrom in forum AutoCAD Civil 3D - Pipes
    Last Post: 2010-07-08, 02:20 AM
  5. LandXML/Pipe Networks
    By eakins in forum AutoCAD Civil 3D - Pipes
    Last Post: 2007-08-31, 02:11 AM
