Thread: default fonts in schedules
    2004-06
    Besançon - France
    3,835
    Default default fonts in schedules
    Hi all
    is it a way to choose the default font in the new schedules ?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: default fonts in schedules
    Right click in the schedule, pick properties, then under the appearance tab, you control the header fonts and field. If you set these in your template then you'll be set. But I don't know of a way to have a brand new schedule default to anything other than arial.
    Scott D. Brown, AIA
    BECK
    2004-06
    Besançon - France
    3,835
    Quote Originally Posted by sbrown
    That's what I want to do.
    2005-07
    Philadelphia
    50
    Quote Originally Posted by gravelin View Post
    Did you find an answer? I want the same thing... and oddly enough, the template I have is using some wonky font by default and I can't seem to find where to change reset it so every new schedule uses plain Arial instead.
    2002-09
    Madison, WI
    5,688
    You can set up a view template, and have that applied to any new schedule you create that will set the font for you.
    However in the newer versions of revit you can now override those fonts in the schedule and set them to something else.
    Very evil when this happens as it's really hard to figure it out.
  1. 8.1 and New Fonts/Importing Fonts
    By briandiercks in forum Revit Architecture - General
    Last Post: 2007-03-05, 11:23 PM
  2. Different fonts have started showing up as default AutoCAD fonts
    By jackie.112886 in forum AutoCAD General
    Last Post: 2006-05-15, 11:02 PM
  3. DWF loses protected fonts - download fonts option?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2006-03-25, 12:01 AM
  4. Converting .shx fonts to .ttf fonts
    By bmichell in forum Inventor - General
    Last Post: 2006-02-02, 02:21 PM
  5. shx fonts to true type fonts
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-03-31, 02:53 PM
