Results 1 to 6 of 6
Thread: annotation scale setting problem
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Default annotation scale setting problem
    Switching over to ACA 2012 is giving me an error when I run my routine:
    bad argument type: lentityp nil
    I have tracked it down to the line: (setq tempDictListEnt (entmakex tempDictList))
    where tempDictList is a list: ((0 . "SCALE") (100 . "AcDbScale") (300 . "6\" = 1'-0\"") (140 . 1.0) (141 . 2.0))
    Did 2012 change the symbol table name of anno scales?
    It could have been 2010, 2011 or 2012.... we are upgrading from 2009.
    2015-10
    Belgrade, Serbia, Europe
    564
    Default Re: annotation scale setting problem
    It hasn't been changed :
    For main dictionary use :
    (entget (namedobjdict))
    For search for dictionary "ACAD_SCALELIST" use :
    (dictsearch (namedobjdict) "ACAD_SCALELIST")
    And for specific scale :
    (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_SCALELIST"))) "A0")
    witch will give you :
    ((-1 . <Entity name: 7ffffb050d0>) (0 . "SCALE") (5 . "10D") (102 .
    "{ACAD_REACTORS") (330 . <Entity name: 7ffffb050c0>) (102 . "}") (330 . <Entity
    name: 7ffffb050c0>) (100 . "AcDbScale") (70 . 0) (300 . "1:1") (140 . 1.0) (141
    . 1.0) (290 . 1))
    As you can see, it's the same as you wrote...
    M.R.
    2003-11
    Chicago
    1,233
    Thanks Marko...
    I'm confused then...
    Why did this routine work in 2009 and now it won't in 2012?
    2015-10
    564
    To add new scale to ACAD_SCALELIST dictionary and CAD environment, you must use this sequence of commands :
    (setq sc (entmakex '((0 . "SCALE") (100 . "AcDbScale") (70 . 0) (300 . "1:1000") (140 . 1.0) (141 . 1000.0) (290 . 0))))
    (entmod (subst (cons 330 (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_SCALELIST")))) (assoc 330 (entget sc)) (entget sc)))
    (entmod (append (dictsearch (namedobjdict) "ACAD_SCALELIST") (list (cons 3 "B7") (cons 350 sc))))
    I used SCALE 1:1000, but you may need different, so you must change (140 . ?) (141 . ?) DXF codes accordingly...
    M.R.
    2003-11
    Chicago
    1,233
    Marko,
    I seem to be doing the exact steps you're outlining except for the (70 . 0).
    What is that used for?
    2003-11
    Chicago
    1,233
    I added the '(70 . 0) to my entity list and it is still giving me the error.
  1. Replies: 10
    Last Post: 2022-08-25, 10:06 PM
  2. Image in annotation scale problem
    By dfi in forum Revit Architecture - General
    Last Post: 2011-11-04, 08:22 AM
  3. Setting Annotation Scale in AutoCAD 2008
    By kdayman in forum VBA/COM Interop
    Last Post: 2009-10-27, 10:25 AM
  4. Purge Annotation Scales That Are Not the Current Active Annotation Scale
    Last Post: 2009-02-01, 06:04 PM
  5. Invalid argument scale in setting standard scale property
    By gtepe.123006 in forum AutoCAD General
    Last Post: 2008-12-23, 02:10 AM
