Thread: Create a polyline Section from surface?
    I could stop if I wanted to scowsert's Avatar
    2006-08
    Olympia, WA
    418
    Default Create a polyline Section from surface?
    Let me see if I can describe this right. We have a surface showing a retaining wall. The plan view of the wall looks like an "S". We'd like to elevate it (aka elevation of it through the center of the whole thing). I'm thinking there must be a way for me to create a polyline through the middle of it. Run some command (which command?) and autocad would spit out the view through the center of the retaining wall.
    Thanks! Sage
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    Default Re: Create a polyline Section from surface?
    Try SECTION command then pick 3 points
    or
    SECTIONPLANE command. Place the section line then Generate 2D/3D section via right-click menu.
  1. 3D Polyline Along a Surface
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2012-11-14, 02:23 PM
  2. Created Surface from polyline contours
    By Tom.Weinstein.137333 in forum AutoCAD Civil 3D - General
    Last Post: 2012-10-26, 02:15 PM
  3. Create a polyline
    By clintonc in forum Dot Net API
    Last Post: 2010-11-18, 06:27 PM
  4. 3D polyline at grade on a surface
    By mhirst in forum AutoCAD Civil 3D - Grading
    Last Post: 2010-08-06, 09:25 PM
  5. Create a Surface from a Closed Polyline
    Last Post: 2007-05-26, 06:42 PM
