Thread: using multiple points for surface
    2011-08
    2
    Default using multiple points for surface
    Hello
    I have more than 4k points from a surveying on a mountain. Now we are creating a road on this road and each time I have to survey the entire mountain again to make a new map while most of that are still intact.
    I would like to know if there is any way to use new points instead of old points on some parts of the surface? so I can use old points for intact parts of this mountain.
    thanks in advance
    2011-08
    2
    Default Re: using multiple points for surface
    any suggestion?
    2015-12
    Arizona
    2,337
    You will want to implement point(s) grouping. And OR an external points database wherein the points you Want to use are stored and all others are omitted.
  1. comparing LDT points to a surface
    By dstapp.144268 in forum AutoCAD Land Desktop - General
    Last Post: 2010-08-23, 09:27 PM
  2. removing points from a surface
    By JRBOURNE in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-13, 09:24 PM
  3. Importing Points to a Surface
    By jdrewreed in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-07-15, 04:47 PM
  4. Adding points to a surface?
    By eraska in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2007-12-04, 03:14 PM
  5. I have points, since I make a surface with these points?
    By sergio_garces_salgado in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2006-10-09, 05:34 PM
