Thread: Error in a sample code ?
    2008-04
    St-Ferdinand, Québec
    141
    Question Error in a sample code ?
    Hi Guys !
    Im realy new to Autocad .NET
    Im using MVS2010 Express and Autocad Architecture 2011
    Im trying a sample in autocad help and I dont know why there are errors ?
    The attached printscreens shows the error in the code below...
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.Interop
    Public Class Class3
        <CommandMethod("PrefsSetCursor")> Public Sub PrefsSetCursor()
            '' This example sets the crosshairs of the AutoCAD drawing cursor
            '' to full screen.
            '' Access the Preferences object
            Dim acPrefComObj As AcadPreferences = Application.Preferences
            '' Use the CursorSize property to set the size of the crosshairs
            acPrefComObj.Display.CursorSize = 100
        End Sub
    End Class
    Thanks in advance !
    5,706
    Default Re: Error in a sample code ?
    Try this instead (changes in red):
    Imports Autodesk.AutoCAD.Runtime.Interop
    Public Class Class3
        <CommandMethod("PrefsSetCursor")> _
            Dim acPrefComObj As Object = Application.Preferences
        End Sub
    End Class
    Tested successfully using Civil 3D 2011.
    Also, when you have an error like that, if you hover the red underscore, you'll be presented a drop down button which usually offers some options to correct the error detected.
    5,706
    Given the simplicity of the task being performed, this can be written a bit more succinctly:
    Public Class Class3
        <CommandMethod("PrefsSetCursor2")> _
        Public Sub PrefsSetCursor2()
            Autodesk.AutoCAD.ApplicationServices. _
                Application.Preferences.Display.CursorSize = 100
        End Sub
    End Class
    2008-04
    141
    Quote Originally Posted by RenderMan View Post
    Good, thanks !
  1. .Net TRANSMITTALLib Sample Code
    By bernie.snodgrass892799 in forum Dot Net API
    Last Post: 2014-01-06, 03:10 PM
  2. Sample code Error
    By r.vetrano in forum Revit - API
    Last Post: 2007-07-09, 11:42 AM
  3. Replies: 0
    Last Post: 2006-04-10, 05:38 PM
  4. Replies: 13
    Last Post: 2004-07-29, 11:38 PM
