Results 1 to 6 of 6
Thread: AutoCAD LT2009 Fatal Error
    2006-06
    8
    Angry AutoCAD LT2009 Fatal Error
    Hiya All,
    I'm running AutoCAD LT2009 on windows 7 and I keep on getting this Fatal Error
    FATAL ERROR: Unhandled e06d7363h Exception at fdadcacdh.
    It keeps happening at random times, like opening a file is a common one or panning around the modelspace.
    •Does anyone else get the same error?
    •Does anyone know what it means?
    •Can Windows 7 and AutoCAD LT2009 handle large cad files?
    Your help/reply would very much be appreciated
    Duaine
    PC: Xeon 3.10Ghz
    4GB RAM
    Nvidia Quadro 2000 card
    0,0,0 The Origin
    8,570
    Default Re: AutoCAD LT2009 Fatal Error
    This might help and, yes, 2007LT + win7 can handle large files.
    John B
    2006-06
    8
    Thanks for the link, i'll take a look and see if I can improve things.
    2006-06
    8
    no good, i got:
    The Page You Requested Was Not Found
    Back to the drawing board!
    All AUGI, all the time clshade's Avatar
    2009-01
    B5
    544
    Charles Shade AutoCAD LT 2014, Dynamic Blocks
    www.cshadedesign.com
    0,0,0 The Origin
    8,570
    I think this is probably the page to which the link on that blog used to point.
    There are several other threads that suggest that this is the cause of various problems.
    John B
  1. 2012: Revit mep: Export to dwg fatal error. Sync fatal error as well
    By Scottybill in forum Revit MEP - General
    Last Post: 2012-11-30, 09:47 PM
  2. Fatal error with autocad 2007
    By apricote in forum AutoCAD General
    Last Post: 2008-11-01, 07:29 AM
  3. AutoCAD 2007 DBX CAS 4 Fatal Error
    By chris.165952 in forum Software
    Last Post: 2008-04-15, 10:13 PM
  4. Replies: 2
    Last Post: 2005-11-04, 01:46 AM
  5. FATAL ERROR - AutoCAD 2004 SP1
    By haneymg in forum AutoCAD General
    Last Post: 2005-05-12, 11:32 AM
