Results 1 to 6 of 6
Thread: Crossing pipe or duct
    2008-08
    26
    Default Crossing pipe or duct
    I have changed the Standard Layer key style, and made a new duct and pipe system defintion.
    But now there is no hidden line any more when I cross a pipe on different levels.
    When i look in style manager, duct system defintions, Display properties
    under "2 Line" is the display component e.g. Contour - hidden or Connector hidden disapeared.
    So I cant change it.
    Is there a way to bring it back again. ?
    Regards
    Menno
    I could stop if I wanted to stykface's Avatar
    2007-11
    Dallas, TX - USA
    352
    Default Re: Crossing pipe or duct
    Don't use the Standard style to begin a new System Definition. Copy/Paste another style and make your necessary changes since most of the AEC Object parameters are already in place.
    Tannar Frampton | Dallas, TX | Engineering Department
    AutoCAD MEP 2012 / Revit MEP 2012 | CADTutor | The Swamp
    2008-08
    26
    I also just find out that the hidden only works in Plan view.
    menno
    2007-11
    Dallas, TX - USA
    352
    This is correct, Plan View only.
    Also note you can adjust these settings by going to Options > MEP Display Control. Under "Crossing Objects Display" you have some options, then at the bottom you have the "Enable Display by Elevation" option which brings the cut plane into play.
    2008-08
    26
    Does this "cut plane" thing not only work with parts from MEP.
    It would be great when you could change elevation views from serveral floor levels with this display configuration. And than with all type off drawings, not only with AMEP member parts.
    2007-11
    Dallas, TX - USA
    352
    Quote Originally Posted by menno.191864 View Post
    Non-MEP Parts aren't intuitive enough to work with the cut plane. In other words, Lines and Polylines and Circles, etc.... those cannot be driven by the cut plane.
    The key is to set up AutoCAD MEP where you're only using the "MEP Parts" so it does work in your favor.
  1. Crossing Pipe Label Style with Elevation and Station at crossing
    Last Post: 2020-03-03, 05:27 AM
  2. Replies: 3
    Last Post: 2015-12-05, 08:19 PM
  3. 2011: Displaying a Pipe In Plan and as Crossing Pipe
    By driggins in forum AutoCAD Civil 3D - General
    Last Post: 2014-10-20, 07:50 PM
  4. Pipe crossing
    By swapr78 in forum Revit MEP - General
    Last Post: 2011-02-04, 07:20 PM
  5. Duct not showing hidden lines when crossing
    By dbanker in forum AMEP General
    Last Post: 2009-01-23, 07:59 PM
