Thread: Designer
    2011-09
    Pittsburgh
    7
    Unhappy Designer
    I"m using AutoCAD 2007 civil 3d, I'm not using the 3d menu. I have a profile I've defined a new finish grade when I go to define it everything disapears including the newly drawn FG alignment in the profile so there is nothing for me to pick as the start point or the whole vert. alignment. Anybody have any ideas? This is the first time this kind of error has ever happened .
    2015-12
    Arizona
    2,337
    Default Re: Designer
    Can you send me a copy of the file in question?
    Did you use the command sequence
    Create Alignment
    Create Profile (from Surface)
    Create Profile View
    Create Profile from Layout?
  1. Designer
    By njmiii_3 in forum AutoCAD LT - General
    Last Post: 2011-09-01, 06:23 PM
  2. Designer
    By gorsandf in forum AutoCAD Tips & Tricks
    Last Post: 2008-03-19, 12:17 PM
  3. 3D CAD Designer in LA
    By awarren in forum CAD Management - General
    Last Post: 2007-08-31, 05:16 PM
