Results 1 to 10 of 18
Thread: Revit light fixture light source geometry won't go away
    Active Member david_spehar's Avatar
    Cleveland, Ohio
    98
    Default Revit light fixture light source geometry won't go away
    I've followed instruction in several posts to isolate and turn off the Revit Light Source objects which I've executed with much success. However...I've run into a glitch. I received a Revit MEP file with lighting fixtures that contain Light Sources that cannot be isolated. They are not assigned the Default Light Source material and when I select the geometry in Navis it is tied to the associated light fixture. Furthermore, when I try to edit the families I can't delete the Light Source. I've attached a screen cap of the lights in Navis with these odd tumors hanging from them. Any thoughts???
    David Spehar, AIA
    Burt Hill
    100 Club mitch.cornelius's Avatar
    2008-05
    Salt Lake City, UT
    171
    Default Re: Revit light fixture light source geometry won't go away
    I think this started happening in the 2011 version of Revit. Certain fixture families prevent you from isolating the light source. The newer versions of Revit won't allow deleting or changing the size of the light sources (from what I can gather). I really don't have a good solution for you...I've just been working around them when I come across them (no fun during clashing).
    If you find a solution, please post it here!
    Cleveland, Ohio
    98
    Thanks Mitch. Not the answer I was hoping to get but at least I know what I'm deailing with. Hopefully someone else will read this and provide the magic answer.
    David Spehar, AIA
    Burt Hill
    I could stop if I wanted to Revit for Breakfast's Avatar
    2010-07
    Halifax, Nova Scotia
    233
    I tell people they are Molars, part of the revit dental add-on.
    “Enthusiasm is the most evident form of passion you can use to fire others up to do their job and apply their own characters to the job.”
    – General Rick Hillier – Canadian Chief of Defense Staff 2005-2008
    Cleveland, Ohio
    98
    Don't believe the hype!!!
    Nice workaround - thanks. Now if only I didn't have to do it for 25 fixture families every time I get a new model...
    David Spehar, AIA
    Burt Hill
    Cleveland, Ohio
    98
    Quote Originally Posted by Revit for Breakfast View Post
    Is my browser playing tricks on me??? This isn't your original post is it? I swear you posted a solution with turning off the Light Source in the individual families. Did I dream that? If so, it worked.
    David Spehar, AIA
    Burt Hill
    All AUGI, all the time pauljordan's Avatar
    Rock -- Me -- Hard Place
    747
    Quote Originally Posted by david_spehar View Post
    You dreamed it.. Only because RFB dream walked into your dreams last night and showed you the way.
    He's got ninja dreamwalking skills.
    Me, I usually just go to the bathroom and the idea comes to me..
    When I used to work for a reseller and was stuck on an idea, my marketing person would say "Go drink some water, it'll come to you." She was right.. It always did.
    Give a man AutoCad, and he'll draw you a floor plan.
    Give a man Revit and he'll build you a house.
    Give Cadmama a couple of drinks and she'll have everyone singing Rockytop!
    Cleveland, Ohio
    98
    You guys are freakin' me out. I'm going back to the Revit forum - they're less creepy there.
    For anyone that'll actually search this post for an answer - the workaround on the table is to disable the light source in the light fixture family. It does work but unfortunately this is required for each family and chances are your engineer won't do it since they rely on the data associated with the light source.
    David Spehar, AIA
    Burt Hill
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    I actually discussed how to do this in navis in my blog. You can look here:
    http://bimnewworld.blogspot.com/2010...t-sources.html
    Regards,
    Teresa
    Teresa Martin
    Senior Application Specialist, IdeateInc
    Ideate on Youtube! http://www.youtube.com/user/IdeateInc
    Ideate Solutions blogs! http://ideatesolutions.blogspot.com/
    Check out my blog: http://bimnewworld.blogspot.com
    Cleveland, Ohio
    98
    Right BUT...the issue I'm having are lights who's light source object cannot be controlled through this nifty search set. If you look at the screen cap in my initial post it'll show you the tumors (or molars as RFB put it) that don't respond to this. Apparently this is the byproduct of light fixture families upgraded from versions of Revit prior to 2011. To the best of my knowledge there is no way to isolate their geometry in Navis so you have to disable the light source in the Revit families. Unless, of course, I missed something in your blog that addresses this with a better workaround.
    David Spehar, AIA
    Burt Hill
  1. 2014: Light fixture does not produce light in rendering
    By ctc in forum Revit Architecture - Families
    Last Post: 2014-04-11, 07:56 PM
  2. 2013: Lighting Fixture Light Source Shows Black After Render in Cloud
    By BIMbeliever in forum Revit MEP - General
    Last Post: 2013-04-12, 01:05 PM
  3. MEP Light Family Without Light Source
    By courtlandtgross in forum Revit Architecture - Families
    Last Post: 2009-10-14, 10:43 AM
  4. 2008MEP/N Light Emitter/Light source
    By jarom in forum Revit Architecture - Wish List
    Last Post: 2007-08-02, 07:15 PM
  5. IES Light Data with Light fixture Family
    By yuthana in forum Revit Architecture - Families
    Last Post: 2007-02-23, 12:44 PM
