Thread: Server can not start job : Error creating plugin instance
    2011-09
    Default Server can not start job : Error creating plugin instance
    Hi all,
    I am new here, say hello to everybody first
    I just want to have a help on my issue about Backburner, one of my node give the info out :"Error creating Autodesk 3ds Max Design 2010 (64-bit) plugin instance"
    Most of the Server (node) is ok, still there is 1 node can not start the job, uninstall backburner on that node, start again, stil same like that. Installed the hotfix for backburner already, still the issue, uninstall and re-install entire 3ds Max Design, the issue still there, can I know what exactly this issue lead on ?
    Hope to have some help.
    Thank you,
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Default Re: Server can not start job : Error creating plugin instance
    What OS are you using? It seems to me that it may be a permission-based problem. I would try disabling the User Access Control (UAC) and your firewall (if you're using one) and see how it goes.
    2004-10
    Denver, Colorado
    1,515
    And btw, welcome!
  1. Vista server do not start up
    By trzmielak312845 in forum Backburner
    Last Post: 2012-10-24, 04:26 PM
  2. Error loading Navis ActiveX Plugin on IE
    By potapczuk542577 in forum NavisWorks - General
    Last Post: 2012-06-19, 09:02 PM
  3. 2012: Revit Server - File crashes when creating new central
    By jperry.68875 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-11-17, 02:45 PM
  4. problem creating instance of column family on a second floor...
    By ntnik in forum Revit Architecture - General
    Last Post: 2009-06-19, 03:28 PM
  5. Error obtaining plugin for Standard Checker
    By Jack Cheong in forum CAD Standards
    Last Post: 2008-01-03, 12:15 PM
