Results 1 to 10 of 19
Thread: Edit Linetype
    I could stop if I wanted to nextvkin's Avatar
    2007-07
    376
    Default Edit Linetype
    Hi,
    I made a linetype in a previous project, and I want to edit it, but I can't find the linetype in my acadiso.lin file. Any ideas please , Thanks.
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Re: Edit Linetype
    You have to load the linetype file (acadiso.lin) and ensure your custom linetype is in the file before changing the line type.
    2007-07
    376
    That's how I did it, but when I open the file acadiso.lin in my support folder (& yes it's in my search path) the line that I made is not to be found, but it's in the drawing. So where can I find it to edit it?
    2006-04
    1,160
    Quote Originally Posted by nextvkin View Post
    In that case it would be either:
    1) You have saved your custom linetype with another lin file, or
    2) You have 2 lin files with the same name of acadiso.lin in different folders.
    2004-08
    Hartford, Michigan
    3,197
    maybe it saved it in acad.lin?
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    2001-03
    Tallahassee, FL
    3,376
    If you make the linetype current you can output the defition to the command line using the lisp here. Copy it to your lin file and edit it there.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2007-07
    376
    I did look at acad.lin, Chris, but it wasn't there either.
    Thanks, Tom, I'll give that a shot.
    I just did - it's great!
    But I'm still curious, why was the line in the drawing but was nowhere to be foud in any acadiso/acad.lin file? I did a search of all the folders in my file path. Not to worry, problem solved. Thanks again, Tom.
    Cairo - no, not Illinois
    4,842
    ....But I'm still curious, why was the line in the drawing but was nowhere to be foud in any acadiso/acad.lin file? I did a search of all the folders in my file path. Not to worry, problem solved. Thanks again, Tom.
    That's because once the linetype is defined in a drawing file, the definition is stored in the drawing's tables. The .lin file is ony needed the first time the linetype is loaded.
    That's why you can use ADC to drag linetypes from drawings on the server into the active drawing.
    2007-07
    376
    Hi Cadtag, thanks for the explanation, but excuse my ignorance, what's ADC?
    2004-08
    Hartford, Michigan
    3,197
    AutoCAD Design Center, type it in on the command line within AutoCAD. It opens a palette.
    Windows 10
  1. Replies: 5
    Last Post: 2013-06-25, 12:40 AM
  2. I'm trying to create a linetype that has 8" in the linetype
    By mikeprentiss in forum AutoCAD Customization
    Last Post: 2006-08-17, 12:11 PM
  3. Extract Linetype information from a custom Linetype
    By H.Hunter in forum AutoCAD Customization
    Last Post: 2006-08-15, 05:27 AM
  4. Replies: 0
    Last Post: 2006-07-22, 05:16 PM
  5. Linetype edit without the original .lin file
    By pmatzler86039 in forum AutoCAD Customization
    Last Post: 2005-05-17, 09:49 PM
