Thread: Wall sweep in plan
    2005-04
    Saintlouis Missouri
    530
    Default Wall sweep in plan
    We have a wall sweep for accent brick and do not want to see it in plan. Any ways around to make this happen. I tried to go into the profile and have it not show say in fine view, but that did not work and under walls I tried to turn off the wall sweep which did not work as well. Any help would be great. Thanks
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Default Re: Wall sweep in plan
    Not sure how you modeled the sweep?
    If the sweep was created with the Wall>Wall Sweep tool ( hosted sweep )
    then under VG uncheck Walls>Wall Sweeps-Cornice.
    see attached.
    cheers
  1. Turn off wall sweep in plan view?
    By ROBinHI in forum Revit Architecture - General
    Last Post: 2012-05-23, 04:02 PM
  2. 2010: wall sweep visibility options in plan
    By phoulx in forum Revit Structure - General
    Last Post: 2011-07-16, 06:29 AM
  3. Wall sweep visibility in plan?
    Last Post: 2006-08-17, 11:42 PM
  4. Wall Sweep visibility in plan
    By GS Fulton in forum Revit Architecture - General
    Last Post: 2003-09-10, 03:09 PM
