Hello!
I started to have problems with some drawings.
The problem is that even though the line/text is red/blue (by layer properties) it displays and plots (!!!) as gray! It's ok in model space but gray in paper space.
I work in Map 2011 and 2012 and the problem appears in both versions.
Blocks are fine.
I suspect that it has something to do with shape files and lines that I created as it started right after I used that lines.
I purged drawing, audited it and it didn't help.
I also use LT 2010 and AutoCAD 2010 and they don't have that problem.
Anyone has an idea?
Thanks in advance for all your help!
Ania
