Results 1 to 6 of 6
Thread: File selection dialog box
    I could stop if I wanted to jgratton's Avatar
    2002-07
    Calgary, Canada
    397
    Default File selection dialog box
    We use 2002 on winxp. Our IT dept is convinced drafting staff are responsible for inadvertantly moving folders while attempting to open drawings. It was demonstrated to me how easy it would be to drag and drop whole folder structures into other folders, and no warning pops up to tell you this has occurred. I was looking for a setting to make this File selection dialog box less powerful.
    If this is not possible, is my only other option buying file management software and which would you recommend?
    2015-12
    Arizona
    2,453
    Default Re: File selection dialog box
    Behold....the power of the untrained user......
    You might try a search for Vaultix.
    Active Member David.Hoole's Avatar
    Yorkshire
    84
    Hi Janet
    The one huge problem with a drag & drop interface is that it allows you to drag & drop
    It's all too easy to make this kind of error using Windows Explorer (I know it happens in our company!), so don't be too easily convinced that it's only CAD users who are causing the problem.
    Unfortunately, the only solution is an EDMS, which can be expensive if you have a lot of users (it's an 'everyone or no-one' thing).
    If you're looking for an EDMS make sure you select one which is designed to handle drawing files. Some do it much better than others. We don't use one at the moment due to the numbers involved, but the best one I've seen so far is CONISIO (do a Google search).
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    535
    Quote Originally Posted by mjfarrell
    And there is only one way to fix that...Training.
    2004-10
    Yorkshire, UK
    402
    The moving folder problems can be sorted by changing file permissions on the folder in Windows NT/2000 Server - you can stop people from deleting things, only allowing them to create new files and ammend existing ones. This is a much simpler (and free) alternative to EDMS.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by ajd
    The moving folder problems can be sorted by changing file permissions on the folder in Windows NT/2000 Server - Iyou can stop people from deleting things, only allowing them to create new files and ammend existing ones. This is a much simpler (and free) alternative to EDMS.
    And you can tell IT that they should have done that in the first place.
    John B
  1. File Multi Selection Dialog (and Folder Select)
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-02-18, 04:46 PM
  2. Replies: 7
    Last Post: 2013-11-16, 11:44 PM
  3. Modify Selection in the Derived Component Dialog Box
    Last Post: 2012-10-23, 03:23 AM
  4. visible mouse arrow in color selection dialog*
    By lcamara in forum AutoCAD Wish List
    Last Post: 2005-08-02, 12:57 AM
  5. IGES Files Selection Dialog Box
    By dave.walker in forum MDT - General
    Last Post: 2005-04-28, 03:06 PM
