Thread: Plumbing Fixture
    2009-02
    4
    Default Plumbing Fixture
    Hi, just one basic (or more) question... I had made a basically (stupid) mistake of doing a family which consist of two or more components (in which i thought would make my teams work easier in doing blow up details and copying etc etc).. and now heres my dilemma... as I was doing a "sample" blow up plans and section which consist of these " family group", I can't cut through these components.. are there any way that I can get my way through this without redoing everything?
    2009-02
    4
    Red face Re: Plumbing Fixture
    well.. apparently.. there are items that Revit can and cannot "cut"... kudos to my team for researching on that item... i didn't know that.. my bad
    2015-08
    84
    Default Re: Plumbing Fixture
    Best way to get around that is to create a section view of the family for the left/right views using linework.
    2006-10
    12
    For whatever odd reason you want to see the plumbing fixtures cut, you could use a 3D view with section box turned on.
  1. 2014: Plumbing Fixture Counts
    By kim579708 in forum Revit Architecture - General
    Last Post: 2015-04-17, 11:24 PM
  2. Plumbing Fixture Heights
    By nubrun.188780 in forum Revit MEP - General
    Last Post: 2009-07-23, 02:27 PM
  3. Plumbing Fixture
    By sjsl in forum Revit Architecture - General
    Last Post: 2008-04-10, 03:31 PM
  4. Plumbing Fixture
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2006-10-13, 01:04 PM
  5. 2D plumbing fixture - behaves like 3D
    By Martin P in forum Revit Architecture - Families
    Last Post: 2004-07-21, 02:22 PM
