This is the latest. The program now adds attribute, text, and dimension values.
And now strips out the first number.
(DEFUN C:AATV (/); LP FAE FAEN FAENL FAENLV FAERT LP1 FAE2 FAEN2 FAENL2 FAENLV2 FAERTS CMDECHO1)
(PROMPT "\n*ADD ATTRIBUTE, TEXT AND DIMENSION VALUES* ")
(SETQ LP 1)
(WHILE LP
(SETQ FAE (NENTSEL "\nSelect first attribute or text: "))
(IF (/= FAE NIL)
(PROGN
(SETQ FAEN (CAR FAE))
(SETQ FAEPT (CAR (CDR FAE)))
(SETQ FAENL (ENTGET FAEN))
(SETQ FAENLV (CDR (ASSOC 1 FAENL)))
(SETQ FAENLT (CDR (ASSOC 0 FAENL)))
(SETQ FAENR (SSGET FAEPT))
(SETQ FAENRE (SSNAME FAENR 0))
(SETQ FAENREL (ENTGET FAENRE))
(SETQ FAENRELT (CDR (ASSOC 0 FAENREL)))
(IF (AND (= FAENLT "MTEXT") (= (SUBSTR FAENLV 1 1) (CHR 92)) (OR (= FAENRELT "DIMENSION") (= FAENRELT "ARC_DIMENSION") ))
(PROGN
(SETQ FAENRELV (CDR (ASSOC 42 FAENREL)))
(SETQ LUNITV (GETVAR "LUNITS"))
(IF (OR (= LUNITV 3) (= LUNITV 4)) (SETQ FAENRELV (/ FAENRELV 12)))
(SETQ FAENLV FAENRELV)
(SETQ FAENLV (RTOS FAENLV 2 4))
));END PROGN/IF FAENLT
(IF (AND (= FAENLT "MTEXT") (= (SUBSTR FAENLV 1 1) (CHR 92)) (AND (/= FAENRELT "DIMENSION") (/= FAENRELT "ARC_DIMENSION") ))
(PROGN
(SETQ LP2B 1)
(SETQ CT1B 0)
(WHILE LP2B
(SETQ CT1B (+ CT1B 1))
(SETQ PAENLC (SUBSTR FAENLV CT1B 1))
(IF (= PAENLC ";") (PROGN (SETQ FAENLV (SUBSTR FAENLV (+ CT1B 1))) (SETQ LP2B NIL)))
);END LP2B
));END PROGN IF FAENLT
(SETQ FAENLVCCS "")
(SETQ FAENLVCPRECTC NIL)
(SETQ FAENLVCPOSCTC NIL)
(SETQ FAENLVL (STRLEN FAENLV))
(SETQ CT 1)
(SETQ FAETRIG NIL)
(SETQ LP3 1)
(WHILE LP3
(SETQ FAENLVC (SUBSTR FAENLV CT 1))
(IF (AND (>= (ASCII FAENLVC) 48) (<= (ASCII FAENLVC) 57)) (SETQ FAETRIG 1))
(IF (> CT 1)
(PROGN
(SETQ FAENLVCPRE (SUBSTR FAENLV (- CT 1) 1))
(IF (/= FAENLVCPRE NIL) (SETQ FAENLVCCPRET (ASCII FAENLVCPRE)))
(IF (AND (>= FAENLVCCPRET 48) (<= FAENLVCCPRET 57)) (SETQ FAENLVCPRECTC 1) (SETQ FAENLVCPRECTC NIL))
);END PROGN CT
);END IF CT
(SETQ FAENLVCPOS (SUBSTR FAENLV (+ CT 1) 1))
(IF (/= FAENLVCPOS NIL) (SETQ FAENLVCCPOST (ASCII FAENLVCPOS)))
(IF (AND (>= FAENLVCCPOST 48) (<= FAENLVCCPOST 57)) (SETQ FAENLVCPOSCTC 1) (SETQ FAENLVCPOSCTC NIL))
(SETQ CT (+ CT 1))
(SETQ FAENLVCC (ASCII FAENLVC))
(IF
(OR
(AND (>= FAENLVCC 48) (<= FAENLVCC 57))
(AND (= FAENLVCC 46) (= FAENLVCPRECTC 1) (= FAENLVCPOSCTC 1))
(AND (= FAENLVCC 45) (/= FAENLVCPRECTC 1) (= FAENLVCPOSCTC 1))
(SETQ FAENLVCCS (STRCAT FAENLVCCS FAENLVC))
(IF (AND (/= FAENLVCPOSCTC 1) (= FAETRIG 1)) (SETQ LP3 NIL))
(IF (> CT FAENLVL) (SETQ LP3 NIL))
);END LP3
(SETQ FAERT (DISTOF FAENLVCCS 2))
(PROMPT "\n Picked number = ")
(PRINC FAERT)
)); END PROGN/IF FAE
(IF (/= FAERT NIL) (SETQ LP NIL) (PROMPT "\nSelection not a real number "))
);END LP
(SETQ LP1 1)
(WHILE LP1
(SETQ FAE2 (NENTSEL "\nSelect next attribute or text /<exit>: "))
(IF (/= FAE2 NIL)
(PROGN
(SETQ FAEN2 (CAR FAE2))
(SETQ FAENL2 (ENTGET FAEN2))
(SETQ FAEPT2 (CAR (CDR FAE2)))
(SETQ FAENLT2 (CDR (ASSOC 0 FAENL2)))
(SETQ FAENLV2 (CDR (ASSOC 1 FAENL2)))
(SETQ FAENR2 (SSGET FAEPT2))
(SETQ FAENRE2 (SSNAME FAENR2 0))
(SETQ FAENREL2 (ENTGET FAENRE2))
(SETQ FAENRELT2 (CDR (ASSOC 0 FAENREL2)))
(IF (AND (= FAENLT2 "MTEXT") (= (SUBSTR FAENLV2 1 1) (CHR 92)) (OR (= FAENRELT2 "DIMENSION") (= FAENRELT2 "ARC_DIMENSION")))
(PROGN
(SETQ FAENRELV2 (CDR (ASSOC 42 FAENREL2)))
(SETQ LUNITV2 (GETVAR "LUNITS"))
(IF (OR (= LUNITV2 3) (= LUNITV2 4)) (SETQ FAENRELV2 (/ FAENRELV2 12)))
(SETQ FAENLV2 FAENRELV2)
(SETQ FAENLV2 (RTOS FAENLV2 2 4))
));END PROGN/IF FAENLT2
(IF (AND (= FAENLT2 "MTEXT") (= (SUBSTR FAENLV2 1 1) (CHR 92)) (AND (/= FAENRELT2 "DIMENSION") (/= FAENRELT2 "ARC_DIMENSION")))
(PROGN
(SETQ LP2B2 1)
(SETQ CT1B2 0)
(WHILE LP2B2
(SETQ CT1B2 (+ CT1B2 1))
(SETQ PAENLC2 (SUBSTR FAENLV2 CT1B2 1))
(IF (= PAENLC2 ";") (PROGN (SETQ FAENLV2 (SUBSTR FAENLV2 (+ CT1B2 1))) (SETQ LP2B2 NIL)))
);END LP2B2
));END PROGN IF FAENLT2
(SETQ FAENLVCCS2 "")
(SETQ FAENLVCPRECTC2 NIL)
(SETQ FAENLVCPOSCTC2 NIL)
(SETQ FAENLVL2 (STRLEN FAENLV2))
(SETQ CT2 1)
(SETQ FAETRIG2 NIL)
(SETQ LP4 1)
(WHILE LP4
(SETQ FAENLVC2 (SUBSTR FAENLV2 CT2 1))
(IF (AND (>= (ASCII FAENLVC2) 48) (<= (ASCII FAENLVC2) 57)) (SETQ FAETRIG2 1))
(IF (> CT2 1)
(PROGN
(SETQ FAENLVCPRE2 (SUBSTR FAENLV2 (- CT2 1) 1))
(IF (/= FAENLVCPRE2 NIL) (SETQ FAENLVCCPRET2 (ASCII FAENLVCPRE2)))
(IF (AND (>= FAENLVCCPRET2 48) (<= FAENLVCCPRET2 57)) (SETQ FAENLVCPRECTC2 1) (SETQ FAENLVCPRECTC2 NIL))
);END PROGN CT2
);END IF CT2
(SETQ FAENLVCPOS2 (SUBSTR FAENLV2 (+ CT2 1) 1))
(IF (/= FAENLVCPOS2 NIL) (SETQ FAENLVCCPOST2 (ASCII FAENLVCPOS2)))
(IF (AND (>= FAENLVCCPOST2 48) (<= FAENLVCCPOST2 57)) (SETQ FAENLVCPOSCTC2 1) (SETQ FAENLVCPOSCTC2 NIL))
(SETQ CT2 (+ CT2 1))
(SETQ FAENLVCC2 (ASCII FAENLVC2))
(IF
(OR
(AND (>= FAENLVCC2 48) (<= FAENLVCC2 57))
(AND (= FAENLVCC2 46) (= FAENLVCPRECTC2 1) (= FAENLVCPOSCTC2 1))
(AND (= FAENLVCC2 45) (/= FAENLVCPRECTC2 1) (= FAENLVCPOSCTC2 1))
(SETQ FAENLVCCS2 (STRCAT FAENLVCCS2 FAENLVC2))
(IF (AND (/= FAENLVCPOSCTC2 1) (= FAETRIG2 1)) (SETQ LP4 NIL))
(IF (> CT2 FAENLVL2) (SETQ LP4 NIL))
);END LP4
(SETQ FAENLVN2 (DISTOF FAENLVCCS2 2))
(IF (/= FAENLVN2 NIL)
(PROGN
(PRINC FAENLVN2)
(SETQ FAERT (+ FAERT FAENLVN2))
(PROMPT "\nRunning attribute and text total = ")
(PRINC FAERT)
);END PROGN
);END IF FAENLVN2
);END PROGN
(PROGN
(SETQ LP1 NIL)
(PROMPT "\nFinal attribute and text total = ")
(PRINC FAERT)
));END PROGN/IF FAE2
);END LP1
(SETQ CMDECHO1 (GETVAR "CMDECHO"))
(SETVAR "CMDECHO" 0)
(SETQ FAERTS (RTOS FAERT 2 4))
(COMMAND "TEXT")
(SETQ LP2 1)
(WHILE LP2
(PROMPT "\nSpecify start point of text: ")
(SETQ TIP (GETPOINT))
(IF (/= TIP NIL) (SETQ LP2 NIL) (PROMPT "\nNO POINT ENTERED. "))
);END LP2
(COMMAND TIP)
(PROMPT "\nSpecify height: ")
(COMMAND PAUSE)
(PROMPT "\nSpecify rotation angle of text: ")
(COMMAND PAUSE)
(COMMAND FAERTS)
(SETVAR "CMDECHO" CMDECHO1)
(PRINC)
);END AATV
