Thread: Need help with 3D piping or hoses
    2011-10
    Default Need help with 3D piping or hoses
    I design 3D hose gages for the automotive industry. I have a hose that is bent in a 45 deg angle. One end of the hose is 1" in dia and the other end is .75" dia and I need to blend the 2 dia's around the corner radius. I am doing this in a solid. Thanks for the help
    0,0,0 The Origin
    8,570
    Default Re: Need help with 3D piping or hoses
    Hi, welcome to augi.
    Try the LOFT command. You'll want a polyline for the centreline to allow you to position (most likely) 4 circles that represent each end of the hose and the ends of the transition.
    Ah, sorry, didn't notice that you're using the 2000 version.
    I don't think it was possible to both bend and taper a solid over the same length until the 2007 ( ? ) version.
    It is possible to do it with a surface mesh though.
    John B
    0,0,0 The Origin
    8,570
    If you do go the surface mesh route, search for m2s.lsp, a lisp routine which will convert many mesh objects to solids.
    John B
  1. Replies: 10
    Last Post: 2016-06-27, 12:04 AM
  2. 2014: Creating hydraulic hoses
    By jlucas in forum Inventor - General
    Last Post: 2015-09-14, 04:42 PM
  3. 2011: hoses
    By StephanieBates in forum Inventor - General
    Last Post: 2011-04-14, 10:04 PM
  4. Trouble with Mapping Hoses
    By stusic in forum 3ds Max - General
    Last Post: 2010-04-29, 02:35 PM
  5. How to Export Animated Hoses
    Last Post: 2009-05-13, 04:40 PM
