Results 1 to 10 of 14
Thread: Project Specific Tags vs. Sheet Specific Tags
    Active Member ChristinaB's Avatar
    2015-12
    Washington State
    80
    Default Project Specific Tags vs. Sheet Specific Tags
    How do I add a project specific tag to my title block So that information has to be input once, instead of on each individual sheet. I want to be able to go to "Setting", "Project Information" and input project specific data here. The only tags that seem to be project specific rather than sheet specific are: Issue Date, Status, Client Name, Proj. Address, Project Name &Project #. Please Help!
    2003-05
    5,153
    Default Re: Project Specific Tags vs. Sheet Specific Tags
    THIS THREAD wll give you the proceedure.
    Scroll down to GuyR's post.
    2015-12
    Washington State
    80
    Question Re: Project Specific Tags vs. Sheet Specific Tags
    That worked great for getting the tag to be project specific. Now another problem has arose.....the tag I needed to be project specific was for a plate height which is called out as 8'-0" Nom. however the tag will only let me enter decimals. Do you know how to get around this so that I can enter feet and inches? I don't see that option under the tag properties. =0
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    When you create the parameter it must be a length parameter or text parameter, not a number or integer.
    Scott D. Brown, AIA
    BECK
    Revit Founder LRaiz's Avatar
    2003-07
    Newton, MA
    714
    Open your tag family (.rfa) file select label and press properties. Edit Format attribute as needed, save and reload into your project.
    HTH
    2003-05
    5,153
    If the tag is a label on a titleblock sheet, formatting is not avaiable, however you should still be able to enter " 8' 0" " as text.
    Quote Originally Posted by LRaiz
    HTH
    2003-07
    Newton, MA
    714
    Quote Originally Posted by beegee
    If the tag is a label on a titleblock sheet, formatting is not avaiable...
    Really? It is available to me. I knew that I was special but did not know that I was so special. I am looking at 7.0 Build 20041213_2030
    2003-05
    5,153
    Well Leonid, yes you are that special
    The image below shows what I get when I try the format button in the 3rd image of your attached graphic.
    ( Build 20041128_2030 - R7.0 )
    2003-05
    5,153
    On further investigation, the Shared Parameter must firstly be formated for either text or length or whatever. ( Which is what Leonid was getting at )
    Once the SP is used in a label on a Title Sheet, no option for formating that label is then available. ( Which is what I was attempting )
    But the effect of using either text or length formats, in this particular case, is minimal anyway, since the label is only being used to denote a constant plate height applying to every drawing in the set, and this can be readily achieved in either format, although the text format does allow for a descriptive handle, as opposed to just the numeric data.
    2003-07
    Newton, MA
    714
    beegee,
    I am puzzled by your findings. I can specify desired formatting and I can assign individual parameter values for each sheet.
    Here is my process
    1. Define shared parameter.
    1.1 File | Shared Parameters | New
    1.2 Specify name and select type = Length
    2. Use parameter in titleblock family
    2.1 While editing titleblock family press Label and select Add button in Select Parameter dialog.
    2.2 In the Parameter Properties dialog press Select... and pick previously defined parameter, then press OK to return to Select Parameter dialog.
    2.3 Format button is available, you can make use of it.
    2.4 Even if formatting is not specified right away I can later select the label using Modify tool, press properties and change formatting.
    3. Load titleblock into project
    4. Use new parameter for drawing sheets
    4.1 Press Settings | Project Parameters.. and select Add button in Select Parameter dialog.
    4.2 In Parameter Properties dialog select Shared Parameter button and press Select..., pick your parameter and press OK.
    4.3 Back in Parameter Properties checkmark drawing sheets category.
    4.4 OK out of Project Parameters dialog
    5. Different values of new parameter can be individually assigned to sheets.
    There a few steps in this procedure but all of them are quite straight forward. I don't understand why your experience different results. Is your procedure different?
  1. Which variables are Drawing Specific and Which are Session Specific?
    By stusic in forum CAD Management - General
    Last Post: 2013-09-10, 01:28 PM
  2. Referring section tags to specific views
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2011-02-16, 07:35 PM
  3. view specific callout tags???
    By wearethestones in forum Revit Architecture - General
    Last Post: 2007-12-13, 11:16 PM
  4. View Specific Level tags
    By sbrown in forum Revit Architecture - Wish List
    Last Post: 2006-05-08, 02:17 PM
  5. Property Specific Door and Window Tags
    By designbank in forum ACA General
    Last Post: 2006-02-27, 07:30 PM
