Thread: Pipe fitting size TAG
    2011-03
    48
    Arrow Pipe fitting size TAG
    Hello,
    Is there any way I can the 'Angle' from the Dimension tab from the properties of a pipe fitting? At present it lists the 'Size' but the angle would be perfect and a lot more use.
    Can I add a category parameter for the angle?
    Any help would be much appreciated.
    2005-08
    11,000 feet atop a chute
    1,001
    Default Re: Pipe fitting size TAG
    You would have to edit the pipe fitting family and add a new shared parameter. Have that new parameter = the native parameter you would like to tag. Than you will have to add that parameter to your tag.
  1. Pipe Fitting and Accessories halftone an half size
    By bhanna888349 in forum Revit MEP - General
    Last Post: 2011-09-19, 09:32 PM
  2. Pipe fitting annotation size
    By RPOY in forum Revit MEP - General
    Last Post: 2010-09-28, 06:26 PM
  3. Pipe Size changes Fitting
    By cdsuggs in forum Revit MEP - Families
    Last Post: 2010-07-26, 09:32 PM
  4. Reducing Pipe Fitting Sizing Issue Based on Pipe Size
    Last Post: 2010-07-22, 08:06 PM
  5. Size of Single Line Wye Pipe Fitting
    By i2mikee in forum Revit MEP - General
    Last Post: 2010-07-13, 08:11 PM
