Thread: Not able to open .dwfx file in Internet Explorer
    2011-09
    20
    Default Not able to open .dwfx file in Internet Explorer
    I was told at a recent siminar on BIM that I would be able to open .dwfx files in Internet Explorer if I had XP SP3 or above as an OS.
    I have tried to open a .dwfx in IE8 but I’m getting an error. My OS is XP, SP3. Note that one of our other users with win7 also can’t open the file. Our IT support also couldn't open the file with three different versions of IE.
    Was the original statement not quite correct or do I need any other installation files to open the dwfx?
    2016-01
    New Zealand
    60
    Default Re: Not able to open .dwfx file in Internet Explorer
    I use windows7-64 and IE9. Yes I can open a dwfx file in IE9 (although I had to specifically filter for "all files" to list the dwfx, and then on openeing it prompted me for permission to run scripts or activeX). All sheets in the dwfx file are viewable. Is there a reason why you dont open the file with autodesk design review instead?
    2011-09
    20
    Quote Originally Posted by nigeld View Post
    Yes, s I don't have it installed. I'm not an Autodesk user. Well not quite true, I've had three days of Revit training.
    2016-01
    New Zealand
    60
    autodesk design review is free, and will even open up PDF files for markup. Very useful.
  1. Get AutoCAD Map to open a file when double-clicked in explorer
    By kskov in forum AutoCAD Map 3D - General
    Last Post: 2007-07-31, 02:10 PM
  2. Internet Explorer for viewing DWF
    By johan d in forum DWF Viewer - General
    Last Post: 2007-01-16, 09:43 PM
  3. Internet Explorer 7 e ADT
    By piegui in forum ACA General
    Last Post: 2007-01-10, 08:57 PM
  4. Windows XP - Internet Explorer 7 To Be XP Only
    By Mike.Perry in forum Operating Systems
    Last Post: 2005-07-30, 01:42 PM
  5. Problem with Internet Explorer
    By minhtct in forum Software
    Last Post: 2005-04-08, 07:05 AM
