Results 1 to 10 of 18
Thread: Plot window randomly offset
    2007-02
    Nijmegen, NL
    9
    Default Plot window randomly offset
    Hello to all,
    I am trying to hardcode X and Y coordinates for multiple plotwindows within ModelSpace.
    The initial plotsettings are made with the common plot dialog.
    The new lowerleft and upperright coordinates are retrieved by GetBoundingBox for several blocks and polylines.
    Sub PlotMultipleAreas()
    Dim Dwg As AcadDocument
    Dim SS As AcadSelectionSet
    Dim acObj As AcadObject
    Dim acBl As AcadBlockReference
    Dim acLwP As AcadPolyline
    Dim ObjectNames As String
    Set Dwg = ActiveDocument
    Set SS = Dwg.SelectionSets.Add("SS")
    Dwg.ActiveSpace = acModelSpace
    With SS
        .Clear
        .SelectOnScreen
    End With
    If SS.Count = 0 Then GoTo QuitSub
    ObjectNames = "AcDbPolyline, AcDbBlockReference"
    For Each acObj In SS
        If InStr(1, ObjectNames, acObj.ObjectName) = 0 Then GoTo NextObject
        acObj.GetBoundingBox pt1, pt2
        With Dwg.ModelSpace.Layout
            .PlotType = acWindow
            .CenterPlot = True
            .SetWindowToPlot ConvPt(pt1), ConvPt(pt2)
            .GetWindowToPlot pt1, pt2
        End With
        Dwg.Plot.DisplayPlotPreview acFullPreview
    NextObject:
    Next acObj
    QuitSub:
    Set SS = Nothing
    Dwg.SelectionSets.Item("SS").Delete
    Set Dwg = Nothing
    End Sub
    Function ConvPt(Pt As Variant) As Variant
    Select Case UBound(Pt)
        Case 1
            ReDim Preserve Pt(2)
            Pt(0) = Pt(0): Pt(1) = Pt(1): Pt(2) = 0
        Case 2
            ReDim Preserve Pt(1)
    End Select
    ConvPt = Pt
    End Function
    I use ConvPt(pt) for transforming two-element to three-element array of doubles and back.
    In the plotpreview / hardcopy there is a significant, constant, totally random offset present. Am I missing something ?
    Thanks in advance for your help.
    Kind regards,
    Erik Wijbrandts
    2007-07
    104
    Default Re: Plot window randomly offset
    I'm having the same issue. I'm using the frame-block to get the "boundingbox" coordinates. The coordinates of my window are passing through fine.
    But somehow the window doesn't seem to start on the proper lowerleftcorner, but somewhere in the center of the drawing.
    One suggestion was to change the postion of ".PlotType = acWindow" so it comes after / before ".SetWindowToPlot". This doesn't do anything.
    Any other suggestions? Or perhaps someone has found the solution? I'm ready to try anything.
    P.S.: Two other threads have been started with the same issue:
    Quick printing with VBA !
    Started by Noureddine, 2012-09-06 02:11 PM
    Problem Plotting with VBA
    Started by cwhitaker, 2005-06-06 06:17 PM
    This one could really use a breakthrough.
    2007-07
    104
    Yes! Found it already. On another site, but posting the solution here for other AUGI users.
    'Pnt1 and Pnt2 are the original coordinates
    Dim Pnt1DCS() As Double, Pnt2DCS() As Double
    'Translate coordinates from WCS to DCS
    Pnt1DCS = ThisDrawing.Utility.TranslateCoordinates(Pnt1, acWorld, acDisplayDCS, False)
    Pnt2DCS = ThisDrawing.Utility.TranslateCoordinates(Pnt2, acWorld, acDisplayDCS, False)
    ReDim Preserve Pnt1DCS(0 To 1) ' Change this to a 2D array for setwindowtoplot
    ReDim Preserve Pnt2DCS(0 To 1) ' Change this to a 2D array for setwindowtoplot
    Quote Originally Posted by CADfunk MC View Post
    Is this case has solved ? I am have some as problem with this
    Print loop in model
    Turlock, CA
    5,656
    If you have a problem, describe the problem in detail. Provide enough information for us to trouble shoot the problem. e.g. show your code.
    C:> ED WORKING....
    My problem i have block with name "kop"
    "kop" is border for A3 paper
    And i want print all "kop" in window and send to printer
    Turlock, CA
    5,656
    That's not a problem. Its what you want to do. The definition of a "problem" is something that is failing. What is going wrong? Remember, I asked for information that we can trouble shoot (try to solve a problem) with. You also didn't show your code.
    C:> ED WORKING....
    2018-07
    10
    Quote Originally Posted by juninawan.wawan784198 View Post
    I found on another forum good for printing, maybe it will help you -Automatic batch printing a multiple format (rectangles, frames) of model space and layouts.
    2018-07
    10
    where is link
    - - - Updated - - -
    Dim i As Integer
    Dim pt1 As Variant, pt2 As Variant
    Dim t As String: t = Now
    Set SS = Dwg.SelectionSets.Add(t)
    With SS
        .Clear
        .SelectOnScreen
    End With
    ObjectNames = "AcDbBlockReference"
        pt1 = ThisDrawing.Utility.TranslateCoordinates(pt1, acWorld, acDisplayDCS, False)
        pt2 = ThisDrawing.Utility.TranslateCoordinates(pt2, acWorld, acDisplayDCS, False)
        ReDim Preserve pt1(1)
        ReDim Preserve pt2(1)
            .CenterPlot = True
            .SetWindowToPlot pt1, pt2
        End With
        i = i + 1
         On Error Resume Next
         Dwg.Plot.PlotToFile "C:\Users\wawang-pc\Documents\0\" & Chr(i)  ' my dwg in so many block but only one show in folder
    NextObject:
    Next acObj
    QuitSub:
    Set SS = Nothing
    Set Dwg = Nothing
    End Sub
    - - - Updated - - -
    where is link that is blank cell
  1. Replies: 5
    Last Post: 2012-03-02, 04:33 PM
  2. How Do I Plot PaperSpace View w/ NO Offset?
    By chillme1 in forum AutoCAD Plotting
    Last Post: 2009-01-14, 12:19 PM
  3. What is procedure for setting Plot Offset?
    By gpapp in forum VBA/COM Interop
    Last Post: 2008-01-10, 02:09 AM
  4. Setting plot window in plot preview
    By IanR in forum AutoCAD Wish List
    Last Post: 2006-04-18, 07:51 PM
  5. WINDOW aSSEMBLY WITH OFFSET DOOR
    By jasontirone in forum ACA General
    Last Post: 2004-12-17, 03:44 PM
