Summary: Add options to create labels to your Assemblies for the Assembly names. This would eliminate the need to create "dumb" text labels or manipulating Fields to work for quickly identifying all the Assemblies in you drawing.
Description: Add an Assembly name label to the Civil 3D template so the Assembly names can be quickly identified in drawings. Right now, you need to manually create, place, and update "dumb" text labels to visually identify Assemblies in your drawings, or create AutoCAD Fields that can be a little more dynamic in labeling them. However, an additional label style within the template and even option within Command Settings to make labeling the Assembly name by default would save a lot of time and effort of having to customize Fields or label each Assembly twice within it's Properties and "dumb" text label.
Product & Feature: AutoCAD Civil 3D
Submitted: Mon, 24 Oct 2011
