Results 1 to 7 of 7
Thread: vertical conduit circle size in medium view
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    632
    Default vertical conduit circle size in medium view
    just wonder if there's way to make that size smaller or at most real size in medium plan view, that's the view we're going to put on sheet, fine plan view will show real size circle for vertical conduit but double line for horizontal conduit which is not desired.
    AUGI Addict Jrobker's Avatar
    2005-08
    11,000 feet atop a chute
    1,001
    Default Re: vertical conduit circle size in medium view
    What...coarse & medium are identical. Fine is what it is, Well unless it's section. Can you explaine further. Not sure I understand.
    JR
    "Keeping my view range hopeful."
    2005-08
    1,001
    JR
    2006-08
    632
    see attached JPGs, single line but circle size is too big in medium plan view, circle size is OK but double line in fine olan view.
    2009-07
    KC
    338
    under Manage > Electrical Settings - you can change your conduit rise/drop annotation size. it's probably at 1/8", which you could change to 3/32" or smaller.
    that's my thought, I haven't tried it tho.
    2006-08
    632
    that's it, i changed to 1/32", looks OK now in medium plan view, thanks moliva.
    2006-08
    632
    that seems only solved half of my problem, another half is in medium plan view there's no way to distinglish different size of conduit rise/drop, for instance 4" Tel and 2" Satellite, isn't it or i'm missing something again?
  1. 2011: view filter for conduit size
    By TJP1979 in forum Revit MEP - General
    Last Post: 2013-09-26, 09:29 PM
  2. 2012: Vertical Pipe not showing correctly in Medium detail level
    By jackcai1026 in forum Revit MEP - General
    Last Post: 2012-07-06, 11:42 PM
  3. Vertical Conduit and Cable Tray Justification
    By pasteele in forum Revit MEP - General
    Last Post: 2011-07-13, 07:58 PM
  4. Conduit Size
    By cparvez in forum AMEP General
    Last Post: 2009-12-13, 10:39 PM
