I'm having trouble with how the wire tag is displaying the circuit numbers. Typically we show them in counting order as 1,3,5. My issue is that they are displaying as 5,3,1. The workflow to get this, is to create the circuits, then move them in the panel, then tie them together as a multi-circuit home run. If they are created in the correct order, they display in the correct order. But if they ever change circuits, the tag displays them out of order. Please see attached videos if this isn't clear enough. The information is correct, but it looks like we can't count. Also this behavior did not occur in 2010 release or the initial 2011 release. It does occur if all the updates are applied to 2011, and it does occur in the 2012 release (with current updates, couldn't test without). Has anyone else encountered this, and if so, how did you address it?
Wrong Behavior (2011-2012):
http://screencast.com/t/kpbo3UyC
Right Behavior (2010 & early 2011):
http://screencast.com/t/jti9k0pkqps
