Thread: Copying, Moving, etc. outside the horizontal Plane
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    405
    Question Copying, Moving, Arraying outside the horizontal Plane
    Could someone let me know what the tricks are to doing these basics?....I'm used to copying/moving in 3D in AutoCAD (...that's probably my problem i.e. trying to think of things from the AutoCAD point of view..) yet I have difficulty in achieving this in REVIT....I've been experimenting with copy/move of some mass objects which is fine on a horizontal plane BUT not vertically (or away from the horizontal X,Y plane anyway)....Is it something readily achievable or is it something that has its problems and should be avoided if possible?
    John Mc
    ...........Update..........
    OK...the "shift" key allows a vertical copying in the section view, but doesn't allow a vertical array!....hmmmm
    2004-05
    792
    Default Re: Copying, Moving, etc. outside the horizontal Plane
    If you are using the '3D button' then yes you can. If you are in perspective views the answer is no, not very much and with much difficulty.
    2003-04
    Chino, CA
    4,756
    Sometimes in Revit, it's necessary to move things vertically, by telling Revit where they stop and start. Just like most other objects, Masses know where they are in space relative to the plane they were drawn on. So to move an object vertically, often times you must move the bottom of the mass up, and then move the top by the same amount.
    For instance, draw a simple extrusion mass on level 1. To move it higher, you either have to define a new plane that it was drawn on, or tell Revit to 'offset' it from the plane it was drawn on. In 3D, you can highlight the mass, and then use the handle points to shift the bottom upward, and then use the handle points at the top to shift the top up by the same amount.
    Also, some objects can be moved vertically, but you must uncheck the "constrain" box in the options bar while in the move command.
    HTH!
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2004-05
    Brisbane, Australia
    405
    Quote Originally Posted by sjsl
    Actually, one of the "offending" views I've been trying this in is the 3D (Isometric) view.....That's probably the only view that consistently limits my copying/arraying/moving to horizontal only!
    2004-05
    Brisbane, Australia
    405
    Quote Originally Posted by Scott Davis
    .........Also, some objects can be moved vertically, but you must uncheck the "constrain" box in the options bar while in the move command.
    OK.....is this similar to toggling the "pin" icon, or is that just for groups?
  1. Horizontal work plane default for drains and diffusers
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-08-06, 06:09 PM
  2. Horizontal forces on Panels using moving Loads
    By JONATHAN.WARDROP882233 in forum Robot Structural Analysis
    Last Post: 2011-10-18, 12:37 PM
  3. How to make a reference plane always horizontal?
    By smm.144 in forum Revit Structure - Families
    Last Post: 2010-10-08, 07:36 PM
  4. Replies: 2
    Last Post: 2005-12-21, 07:54 PM
  5. Mask difference on vertical plane vs. horizontal plane.
    By SkiSouth in forum Revit - Rendering
    Last Post: 2004-04-24, 01:08 PM
