Thread: Laser scanning survey
    2010-03
    2
    Default Laser scanning survey
    Hello All,
    We are about to hire a consultant to do a laser scanning for our tunnel. The deliverables that they will provide us are:
    1) From the laser scanned pointclouds, they will develope a C3D surface model of the top and the bottom of the tunnel.
    2) they also provide a thinned version of the pointclouds in AutoCAD DXF format. In this file, the tunnel will be displayed in AutoCAD points
    3) The complete laser scann in Leica TruView format.
    With my limited knowlegde of C3D, I'm OK. with the item #1, but I'm sure when they uitilize this surface, they need to thin down the pointcloud so some small overhang will not be shown on the surface. Secondly, I don't see any benefit to get the DXF files, because AutoCAD points (not C3D points) are useless.
    Here is my question:
    With your experts of knowing C3D, what do you think about their deliverables? Can someone give me some comments about these?
    Thanks much
    D
    2015-12
    Arizona
    2,478
    Default Re: Laser scanning survey
    Actually the autocd points in DXF are not 'useless' you can use them within a surface to build a smaller, faster version for general modeling, design visualization tasks; that do not require the full accuracy of the entire point cloud.
    To use Autocad Points; investigate the Points dropdown>>>Convert Autocad Points
    sounds like their deliverables will serve your needs as you have explained them.
  1. PD33-1: Plant Design and Laser Scanning: It's Ready for Prime Time!
    By Autodesk University in forum Plant Design
    Last Post: 2013-04-17, 04:22 AM
  2. 3D Laser Scanning - Revit Workflow
    By sfraney in forum Revit Architecture - General
    Last Post: 2010-11-16, 11:19 PM
  3. Point Cloud (laser scanning) database in NavisWorks
    By Amirek1 in forum NavisWorks - General
    Last Post: 2009-09-04, 08:50 PM
  4. 3D Scanning.... wow
    By sfaust in forum Revit - Hardware & Operating Systems
    Last Post: 2008-05-31, 03:49 PM
