We are looking for the best known method to export from Revit to AutoCAD DWG files with External References and viewports.
We created a model in Revit and produced the construction documents directly from the model. Now the project is complete and we need to hand over the drawings to the customer. Since the customer does not use Revit, we need to export the drawings to AutoCAD. The customer expects to receive DWG ‘models’ referenced into the Model Space of a series of DWG Sheet files. They want the models to be shared between all of the drawings in the series in such a way that updates to one ‘model’ is reflected in all of the AutoCAD sheets that reference that model. (For example, if a door swing is changed in the ‘model’ DWG, all of the Sheets will show the change.)
We have tried exporting to AutoCAD with Export Views on Sheets and Links as External References. Unfortunately, when Sheets are exported from Revit, the views on each Sheet are exported into a series of XREF that are not shared between sheets. We are looking for a better method as this will not meet our customer’s expectations.
Thanks in Advance for your support!
