When sectioning, I'm constantly getting incorrect section views, with only a few items sectioned.
When I've contacted our support guy he’s stated that I have to create a sketch and manually create the hatching, is this correct?
regards
Wayne
regards
Wayne
Sounds and looks like a classic case of "Section standard parts". You have an option where you can tell Inventor to section (or not) standard part such as bolts, steel beams or piping taken from the Content center.
Double-click on your view to bring up the view properties. In the "Display options" tab, there is a drop-down box called "Section standard parts". Select "Always", and "OK". It should do the trick.
Passez un très belle journée.
Merci Pierre
Qui travaille un régal (that works a treat?)
We pay quite a nice sum of money for our support too.
Nice to know there is a better option than sketching the section.
Thanks again
Wayne
