Hi,
I'm interesting in some tutorial for to create intersection between two roadway, with deceleration and acceleration road.
Somebody know any?
Thank
Hi,
Somebody know any?
Thank
Did you try the Autodesk tutorials?
http://docs.autodesk.com/CIV3D/2012/...B21A611A-0.htm
thank you Jeff,
I know and I saw those tutorials, but my problem is that I don't know how to make one deceleration or aceleration lane between two road separated same picture attach. Tutorials learn how to build one intersection with alignments at the same level. I need to create independents alignements like de a big intersection.
tranks.
You have two options;
One send me a copy of your base file and I will difine the alignments for your proposed roadway geometry for you. Or, you will need to define the alignments for your proposed geometry.
There are a coule of key 'tricks' that you will need to employ in making this interchange to interchange design work.
For your accel-decel lanes, you will want to use either a superimposed version of the main raods centerline, and or edge of pavemeent profile, within the accel-decel lane alignments profile view, this will allow you to create the vertical design such that they match at the desired levels.
Or you can create a temporary portion of the corridor surface and include that in the profile view so that your tie-in points are visible within the profile. (Profile >>create Surface Profile>>select the corridor>Click ADD; when you click OK the surface will appear in the existing profile view(s) )
