Thread: XREF layers revert back after closing dwg?
    2009-07
    25
    Default XREF layers revert back after closing dwg?
    Hi all...
    having layer trouble. i have an xref with certain layers that i use in some drawing viewports and freeze in others. but after i close the drawing and open it later, the layers are all on again. I've played with the VISRETAIN variables but none seem to help.
    Any suggestions?
    thanks
    Lee
    2004-08
    Iron Station, NC
    3,198
    Default Re: XREF layers revert back after closing dwg?
    VISRETAIN has to be set to 1. anychance you have a lisp routine running that modifys something. or possibly a layer state that is saved with a particular view?
  1. Revert from Wiggle Pen back to CAD lines?
    By ROBinHI in forum Impression - General
    Last Post: 2022-10-19, 09:33 AM
  2. 2013 Inches Revert Back to 0.0 on Transforms
    By ben.bringardner in forum NavisWorks - General
    Last Post: 2013-01-18, 10:30 AM
  3. Changes to viewport layers revert on Xref reload
    By aswartzell in forum ACA General
    Last Post: 2007-07-13, 04:43 PM
  4. Replies: 3
    Last Post: 2006-09-22, 08:22 PM
  5. qsave = revert back
    By sturner in forum AutoCAD Map 3D - General
    Last Post: 2005-02-08, 09:53 PM
