Thread: a hatch that works as with Solid Hatch but in reverse, by masking in white instead of black/color
    Wish List Administration
    2011-08
    4,581
    Default a hatch that works as with Solid Hatch but in reverse, by masking in white instead of black/color
    Summary: wipeout hatch pattern
    Description: AutoCAD should have a hatch that works as with Solid Hatch but in reverse, by masking in white instead of black/color. this would all but eliminate the need for conventional wipeouts, and also allow curved areas to be masked.
    Product & Feature: AutoCAD
    Submitted: Wed, 16 Nov 2011
    0,0,0 The Origin
    8,569
    Default Re: a hatch that works as with Solid Hatch but in reverse, by masking in white instead of black/color
    Set your solid hatch to Truecolour 255,255,255.
    John B
    2011-04
    99
    Lightbulb Re: a hatch that works as with Solid Hatch but in reverse, by masking in white instead of black/color
    @jaberwok, thanks for your comment
    setting the Hatch color to 255,255,255 works to a limited degree, however it is quite distracting to work with, especially for users with the AutoCAD default color settings, and it produces unpredictable results when you print to PDFs, to image formats, or output devices with ICM-adjusted profiles.
    it would be far simpler to replace the Wipeout command with a non-printing, Solid Hatch, set to match the drawing background color (this has been an Mtext option for 7yrs, in case you weren't aware).
    2011-08
    4,581
    Exclamation Re: a hatch that works as with Solid Hatch but in reverse, by masking in white instead of black/color
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. Replies: 18
    Last Post: 2008-11-10, 05:47 PM
  2. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  3. Reverse image so linework is black & background white?
    By crohloff.72988 in forum AutoCAD General
    Last Post: 2006-11-28, 11:35 PM
  4. White solid hatch turning black
    By jv3dcad in forum Revit Architecture - General
    Last Post: 2006-01-29, 03:13 AM
  5. White hatch prints black...
    By designer56644 in forum Revit Architecture - General
    Last Post: 2004-03-16, 03:11 AM
