Thread: Linking Drawing Properties with attributes
    2006-03
    San Cristobal, Guatemal
    439
    Default Linking Drawing Properties with attributes
    How do I Link a title block attributes with the Drawing Properties dialog box? This allows for titleblocks in multiple sheet layouts to be edited at one time. Pleae advise. Thanks
    2001-12
    St. Louis
    5,406
    Default Re: Linking Drawing Properties with attributes
    I would typically use FIELDs for this, but, I typically associate my drawings to Sheet Sets and get the properties from there (such as the name of the project).
    It seems that you should be able to use the file properties in the same way, but, I've just tried it out and can't quite seem to make it work...
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2006-03
    439
    Thank you for your responce, I was able to find the way to do this through one of Ellen Finkelstien's older tips. Very similar to what you were trying to do.
    Cairo - no, not Illinois
    5,069
    Wanderer
    That screen shot looks like XP - I'm able to do this with fields in Win7 and used to be able to do it in earlier versions of CAD with XP. But at some point Adesk updated the DWGProps to work better with Vista's NTFS version, and that created problems with XP.
    That's why in XP (with current versions of AutoCAD installed) if you do Properties you can see two Details tabs, one grayed out (which is updatable via DWGProps in Acad, and one that can be edited outside of CAD, and show very different information.
    2001-12
    St. Louis
    5,406
    Wanderer
    Ah... my IT department strikes again (my machine came with Windows 7, but, they took it off and put XP on. Yak.
    I had the drawing properties added to the file through explorer.
    Out of curiosity I might try this again when I get home to my Win7 machine.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. 2012: Linking Attributes
    By pdstro in forum AutoCAD Customization
    Last Post: 2012-08-17, 02:02 PM
  2. Replies: 0
    Last Post: 2011-11-15, 01:35 PM
  3. Linking Attributes
    By Kio in forum AutoCAD Customization
    Last Post: 2009-04-07, 10:59 PM
  4. How to link Block Attributes to Drawing Properties
    By dhendrickson in forum AutoCAD General
    Last Post: 2007-06-06, 08:38 PM
  5. Replies: 1
    Last Post: 2007-04-10, 06:22 PM
