Thanks RenderMan for the direction, unfortunately I need a little more hand holding to get this to work...
I made a .txt file into and named it in your honor.... HTH.lsp because I do not know what it is and I needed something to start with.....
Then I copied your code from above into it. Saved in on my C-Drive (for now); then went to appload and loaded the HTH.lsp.... HTH.lsp on the command line, nothing.
What did I need to do that I did not pick up on to do. I know somewhere along the line, I will need to specify the name of the .dwt.
Thanks in advance
