Thread: My AC2004 run on Windows 7?
    2008-09
    80
    Unhappy My AC2004 run on Windows 7?
    Thinking I was doing myself a favour I upgraded WindowsXP to Windows 7. Result - AC installs but wont run. The problem appears to be XP is 32bit and W7 is 64bit. Does anyone know of a workaround or a fix? 64bit versions of AC are expensive. Thanks
    RD
    0,0,0 The Origin
    8,570
    Default Re: My AC2004 run on Windows 7?
    You should be able to run in compatibility mode but, if you have the Pro, Ultimate or Enterprise edition of Win_7, you are entitled to download and use Micros**t's "XP mode" emulator or you can use any virtual pc software like - VirtualBox.
    2008-09
    80
    Quote Originally Posted by jaberwok View Post
    Thanks John. I tried the first option but discovered I dont have the right edition. I'm about to try the Virtual box. Seems complicated at first glance but I'll soldier on. Cheers.
    Roger
  1. 2014: Windows - Embedded Windows and Floor plan Views
    By hworrell in forum Revit Architecture - General
    Last Post: 2014-07-18, 04:50 PM
  2. Bay Windows - True Bay Windows cannot be created in Revit or can they?
    By robinhill833400 in forum Revit Architecture - General
    Last Post: 2012-10-03, 03:55 PM
  3. Replies: 3
    Last Post: 2009-09-15, 04:09 AM
