Thread: Initialize Macro in VSTA
    2007-10
    47
    Default Initialize Macro in VSTA
    I am using C#.
    Is it any difference between those two initialization below?
    Autodesk.Revit.UI.UIApplication app = this.Application;
    1.) Autodesk.Revit.DB.Document doc = this.Document;
    2.)Autodesk.Revit.DB.Document doc = app.ActiveUIDocument.Document;
    If they are the same which one is the most commonly use?
    Thanks in advance
    2001-07
    Dallas
    19
    Default Re: Initialize Macro in VSTA
    Quote Originally Posted by ckc.mike View Post
    I am using C#.
    Thanks in advance
    I'm not sure if there's any right answer here, ..it boils down to your preference and programming style, VSTA gives you both "this." for c# and "me." for vb.net.
    If your goal is to remain in VSTA then your safe, .. however if you are to port code over to API dll's then you may want to consider avoiding "this."
  1. CP222-2: Autodesk Revit VSTA: Writing Your First Macro An Introduction to the Macro Manager
    Last Post: 2014-12-01, 02:12 AM
  2. can't create VSTA MACRO Revit 2013
    By avzalingen811374 in forum Revit - API
    Last Post: 2012-09-25, 11:19 AM
  3. Revit architecture macro VSTA tutorial
    By hhhnzw in forum Revit - Tutorials
    Last Post: 2011-06-05, 11:56 AM
  4. Share VSTA macro's? Or build them in Visual Studio?
    By nicholas.hendrickx in forum Revit - API
    Last Post: 2009-05-19, 08:04 AM
  5. Revit Architecture 2009 VSTA Macro Manager Bug?
    By FWSchreck in forum Revit - API
    Last Post: 2009-03-27, 05:22 PM
